750ss carb balance
sorry mate, sudden loss of brain in my dinner!!
look up(on the righthand side of bike) from the front wheel at the underside of the carbs, see where the two control cables are attached to the retaining plate which is in turn attached to the carb bottom. The idle screw is located above that. It has a spring on the screw to keep the tension.
I copied this from the other thread you had. the balance screw is right next to this one. It is also retained by a spring. I personally use vac-gauges to get them as perfect as one can with CV carbs.
You'll want a long crosshead scewdriver with a blade length of about 6". The balance screw is the one which is furthest back and almost inaccessible between the carbs. Access is easiest got by lying along side the bike and be prepared to get your arm a bit hot :eek:
