750ss breathing problems
lintonjag
New to the site but joined after the meeting at Dunfermline.Got a daft problem on a 750ss bought from E-bay,bike was o.k. but too quiet with the standard pipes on,so i got myself a set of Viper Oval cans from demon tweeks,the cans and connecting pipes fit o.k. but the pillon footrest bracket in it's normal position will not match up to be placed back onto the frame and help support these cans.Anybody else tried these cans on a 1999-750ss?Tried alsorts,but don't really want to go down the road of having to either make or buy new footrest hangers.:banghead:
Sorry L, can't help with that. Got a picture of it?
Your round anyway.
what model of 750SS and what were the cans actually for? the SS changed at the end of 98 into the new Terblanche designed shape but if the bike was an early 99 reg it could still be the older square headlight version, if cans are for a 99 oval headlamp and you have a square that could the reason they don't fit.
Welcome to the forum Lintonjag. I can't help you with the zorst problem as I don't know these pipes, but nice bike sir. :)
Breathing problems
Hi Gizmo,the 750ss is new shape(Terblanche),wanted to put decent noise silencers onto the bike as the standard pipes mute the sound a bit.Seen an older modeled 750ss at the last race meeting at East Fortune ,looked o.k. and sounded like a Duke should,just wished i'd had my camera with me and taken a photo of how that owner had mounted theirs.The exhaust cans are fitting on no problem,it's just that i have to remove the pillion footrest hanger for them to sweep up the side of the bike rather than stick out like Dumbo's lugs,and even with the hangers off,there is a hell of a gap to actually put the mounting hangers on to the frame to take the weight of the pipes,feel a right numpty.:comp2:
are they high level ? the same as my superlight go to my bike pictures to see
link next to avatar
I had the same problem with my Tereblanche 900ss when I ordered Art cans for it. They first came with connecting pipes for a carb SS (cans wouldn't bolt to rear footrest brackets) and the replacement connectors were for a monster, they finally got it right the 3rd time. If your cans have separate connecting pipes I would guess that's the problem.
Breathing Problems
Thanks for the info,will check next time i'm home(away back to sea)hopefully the info should get them to fit on the bike.
link next to avatar
Yes they should come up to roughly the same height as your ones do but i'm not sure they come as close to the bike as your ones,will have to wait till i'm back from work in a couple of months to try and work something out.Many thanks for your info.Graham.:thumbs:
