Coddy
Was supposed to be doing a track day at Knockhill today, but had to miss it, because my 749s track bike wont start.
I get the impression its not getting fuel.
If someone here has a 749 with a Power Commander 3 fitted, can you tell me if when the bikes ignition is switched on, the green LED lights on the PC3 are also on.
Removed the plugs, and the bike is getting spark.
The fuel pump is priming.
Can only think the PC3 is either not working (no lights working) or if it is working, its not telling the injectors to operate.
When plugs are removed they are dry.
Tried to bump start it prior to thinking its lack of fuel with the use of the rear wheel of a quad bike against back tyre of 749 (cheap version of Moto Gp starter) but the slipper clutch doesn't allow the engine to be turned over.
