testastretta
Decided over this winter I would get the rear shock off - I'd been running with a pretty crap hugger for a while which allowed the spring in particular to get blasted with stones from rear tyre. It looked awful.
After starting the strip decided I may as well check swing arm bearings - expecting to find nothing, since bike had been handling superbly before it was laid up (...in the dining room, sad I know).
On the swing arm, the L/H side is needle roller bearings and the right its glorified wheel bearing type. The needle roller bearings were almost completely dry and the spacers ( they look like top hat) had imprints of the roller bearings on their surfaces. The amount of movement of course at swing arm bearings is a relatively small arc, which doesn't help I suppose, but it doesn't appear that whoever assembled them was particularly generous with grease in the first place ? My bike only sees rain when we get caught out in it.
Harry is organising the full set of bits for me.
On the shock spring, harry pointed me to Trevor at ESP. Absolutely delighted with it - shot blasted and powder coated its transformed and at the price Trevor charged its awesome result.
Thanks to all for your help/guidance.
