749 Replacement Engine Installation
749Tomi
I have or had a wonderful 2003 749 with 5K on the clock, full dealer service history, not a track day in its life and the big end bearing went (not uncommon apparently....)– costs from Ducati to fix it 2.5K!! Here is the thing; instead of forking out 2.5K I have acquired a replacement engine. The old engine is out of the bike, and I need the replacement engine installing and the bike putting back together. Simply cant afford to have this done by Ducati, anybody recommend any North East workshop or individuals (fully confidential of course via the private message feature) who could do this at a reasonable cost? The only other alternative is the scrap the bike and sell it off bit by bit on flea bay. Any advice or information would be appreciated. Cheers, Tomi.
In reality this shouldnot be much of a job, says I LOL !
If its just a case of slotting a new motor in and the old one is out I guess any competent mechanic could do it easily in a day, maybe download a manual and have a look at it, may not be as hard as you think if all the electrics are labelled and you have all the nuts and bolts !
Like dseered says it shouldn't really be such a big job and if you have the time and the space why not do it yourself. Even if you have to buy some tools (you won't need much) it will still be your cheapest option. A few years back I had to swap the frame on my 900ss when it cracked (Ducati supplied a new one but I did the work) and that was even more work because every thing had to come off.
You will need to remove the bodywork, tank, radiator, airbox etc. and unplug all the cables and wires. Support the bike under the engine, then after unbolting the rear suspension, remove the 2 engine bolts and lift the frame and front end away from the engine/swinging arm assembly. You will then need to remove the swinging arm from the old engine and fit it to the new one. Then put it all back together again - That's sometimes the hard bit for some people ;)
You can download a manual here for a small fee. I would do the swap for you but at a couple of hundred miles away it is hardly practical. I do hope you manage to get it done one way or another, it would be such a shame to scrap the bike.
How common is big end failure here then Derek? Any idea at all? Just that my mate has recently bought more or less this exact same model. I'd hate it to go pop on him. So would he! Any idea of cause Tomi?
No idea Pete. I've only heard of one other case of big end failure on a recent bike. If a bike has been dropped and the engine is still running the oil pick-up pipe can draw air and starve the big ends and mains of oil leading to premature failure but normally Ducati bottom ends are pretty robust.
wasnt this why they introduced the deep sump? something to do with the race bikes being starved of oil causing bottom ends to go, don't think it was a big issue on road bikes.....i hope :confused:
il have a go at it for you im reasonably competant and ive got two hammers for when all else fails ;)
It won't make much difference how deep the sump is when the bike is lying on it's side!
I have never heard of one go Pete, not saying they don't but it certainly is not a common fault - yes it is said if they have been down on their side while running it can cause a later failure as others have said !
if you are going to replace it yourself get a digital camera and take photos of where everything is as you strip it, put bolts into poly bags marked with what they are and draw a little diagram on the bag if bolts are different lengths. tape male and female connectors with a unique tape or mark, have the old engine alongside so you can mark the new engine connector against its frame connector.
you may want to try V twin Service in Consett, he's got a good reputation for servicing Ducati's.
It must be rare for one to go or we would have heard lots about it! In the 70's it happened to a friends 860GTS and we found out it was because he had been putting Castrol instead of Duckhams in the engine. In those days you didn't have specialist bike oil so you had to change it every 1k miles.
If it is a common failure as you say surely there will be other reported incidents where this work has been carried out by Ducati under warranty or outside of warranty as a gesture of good will?
A few 748 have suffered such a failure but without knowing the full and complete history of the bikes involved that might have contributed I wouldn't say it was an epidemic. The 749 is a testastretta motor but its not a deep sump motor as far as I know.
Sorry I don't know of anyone that far North who might do the job at a reasonable price. I'd guess that even if it only took a day to swap you'd be looking at maybe £200 or more, don't forget its not just the labour, theres fluid and sundry stuff that might add to the bill. Any half decent independant bike workshop ought to be able to do it but make sure you get a quote, labour rates are gonna have a big effect on the price.
Hope you get sorted without breaking the bank.
Ray.
Give Darryl a call at DIT motorcycles - 0191 417 2787 - in washington (his unit is close to Nissan). He's Ducati trained and did all the spannering on my 748s and my mates 748r. His humour is VERY dry but he's a great guy!
Loz on DSC had problems with his 999 as I recall. Something to do with incorrect shims (not the valve shims) and it went bang.
May be worth dropping him a pm.
