749 oil light flickering on and off
Finchy
Carried out an oil change and ran up 300 miles approx, got home, washed bike and the oil light is flickering on and off! Plenty of oil in the engine so is it the pressure switch and what do you advise to go for e.g. Ducati, alternative. All advice including any part numbers most welcome. Thanks Ian.
PS Possibly I may have scooshed water into a connector plug ��
Hi Finchy, its extremely common for the oil pressure sensor to begin failing. I've replaced one on my 916 doing exactly like yours and my 900ss has started doing the same! There is a newer version however how much better it is I don't know. I believe some have even removed the sensor and blanked off the threaded hole it sits in!
I'm sure you'll get many tell you very similar stories :)
Oil Pressure switch my Monster is on its third gets wet and shorts out or leaks oil
Vauxhall Car Part Intermotor 50938 cheap one about £6 Igela ! corsa !
also a blue plastic one cannot find Number twice the price but twice the quality thats the one i am using motor factor should be able to find
Intermotor part no 51145 blue body 0.4 bar switch point with internal filter
0.29 -0.53 bar old type 50938
got price wrong £5.84 + vat for the blue one just bought 2 if you need one pm me
Thanks all
Ha ha looks as if I was overwhelming adventurous with the hose and skooshed a connector. Stripped it, dried it and whey hey back working okay. However I am very grateful for your expert help and will keep a note of the recommendations. Cheers the now. PS just noticed a "tick" fixed onto my Lab's Crown Jewels. I have the tick remover ready, he's lying upside down but before I attempt the removal I'll have a dram of whisky first!
