05 749 BP 7000 miles just had an almighty expensive service.....
Hi all,
Just decided to go out for a spin. Started fine until after about 1/4 mile and she starts to hesitate (feels like fuel starvation) then stops all together
Switches off and tries again. Straight away the engine light comes on as she fires up only to die almost straight the way. In the background a half hearted wirring noise that won't stop with the key or even if I take the fuses out near the instrument panel. Managed to push her back home loosing two stone in the process! Only got the wirring noise to stop by disconnecting the lower of the two fuses by the battery. Wirring noise sounds like the fuel pump at half chat, although location wise it sounded like something behind the oil cooler.
Is it:
A) an easy fix? or
B) time for Panigale?
Regards
Bryan
Hi all,
Is it:
A) an easy fix? or
Regards
Bryan
