mine wont when cold with out fast idle. if its wet it needs a dash of fast idle too. has it got termi's / chip? prolly pop it into a Duc specialist, pretty sure they can tweek the settings fairly painlessly.
the 03 ones were known to have issues with the plug caps which are on turn the ignition coils. the early ones had a connecter actually on the cap which easily broke, the newer ones have a short 'tail' with the connector at the end.
I have seen a few posts re idling on the 749 range, usually cured by a Ducati centre with a diagnostic tool.
Just fitted 2 updated coils from an '06 plate that was crash / damaged, picked then up for £50 for the both and they look like they have just come out of the box! Would have been around £180 new.
I would say that the coils are not the cause of it not ticking over correctly but more of a TPS reset and setting the mixture ratio for both pots with the C02 analyzer.
It would also benefit by dialling in the cams to 113/113 as I believe they did on the newer ('05 onwards) which gave better idle speed but changed the power delivery slightly...
