749/999 Rear caliper relocation bracket ?
  • Thread starter Thread starter iang27
  • Start date Start date
I
iang27
Just visiting
Has anyone fitted one of the rear caliper re-locating brackets that move the caliper to the bottom of the disc.
If so did the existing hose fit or is a longer one needed, does it affect the braking at all and does it look good or not ?
I'm not 100% but I think you need a long brake line, I don't think it makes any difference to braking my understanding was that it aided stability
Not the same bike, but when the rear brake on the SS was moved from above to underslung it got a brake line about 12" longer. The underslung caliper was a pain in the @rse to bleed, you had to remove it from the bike and hold it the right way up.
Same as Derek says - different bike but - on the SL the underslung conversion came with longer braided hose. If you think about it, the banjo connection would move over to the opposite side of the caliper.
After I had it fitted to the SL the back end tended to skip less under braking.
