749/999 Owners Please Read
chrisw
How many of you have had the coolant hose chomped through by the cooling fan on the radiator?
If you haven't have you checked the hose on the left handside of the engine. It's the narrow hose that links the rear cylinder to the radiator. See if it is damaged by the fan.
Please post here if you have suffered the cooling hose failure or have found damage to the hose.
Yep its the small hose on the top of the rad on the left hand side as you are sat on the bike, had the fan etc replaced under warranty after it warmed my leg up on the way to Oulton.
Dibble and Freak got me going again with some spare fuel line we happened to stumble across in the paddock.
The hose is badly routed from factory.
Chris as you know I've got the same issue but my hoses are fine, saying that the issue did manifest itself after washing the bike maybe water has somehow found it's way into my ECU?
I'd of thought a motor vehicle ECU would be sealed from the elements especially on a bike
Freak, I'd have thought it would be well protected too. But it isn't ! It only has a heat shield over it. If you haven't looked where the ECU is then you will find it below the battery box. If you look at the sloping part below the battery you will see two allen head bolts. These actually hold the ECU in place. It will give you an idea of where it actually is. Getting it out is another matter and involves removal of the battery and battery box.
yeah I know where it lives, and I've seen the battery box off when JHP checked it over a while ago, more like a birds nest of wires back there thus why I haven't had the thing off since.
As discussed over PM I do have the standard ECU which I might fit to see if it's definitely an ECU issue and then go from there
