748SP AIR screw
There is no set position for the air bleed screws. After setting the TPS the air screws should be wound fully in and the throttle body balance set. The air bleeds are then wound out to achieve the desired idle speed and balanced to match each other with a CO meter. Usually they will be about 1 turn out but not necessarily the same. Full set up procedure here
Oh Aye, and welcome to the forum :)
