748 wheel bearings
clufster
Just bought some marchesini from flea bay and am going to get them powder coated black. I have got remove the wheel beings which are going to be replaced. I was going to tap them out with my big screw driver but I am now thinking this is a bit gash. Any tips on removal and refitment. Years ago had access to a 100 tonne press, not any more.
regards Stewart
The OEM wheels have a spacer that you can get a punch on and use as a drift. If there isn't one in your Marchesini then you don't have much option than to drift them with something, but use something a bit more blunt than a screwdriver ;)
Hi Stewart
You wont need the press,and as pict says there is a spacer between the bearings which has a small slot in one end which should allow you to get onto the bearing, a bit of tapping should knock them out,failing that an internal bearing puller.I'd replace the bearings with 2rs as opposed to zz and stick to recognised bearing manufacturers as opposed to the £ jobbies on ebay,cant vouch for their quality.
ps thatll be satin black :thumbs:
hi
not sure if this will be of any help, but please find the attached PDF drawing of the rear wheel bearing spacer for an ST4s showing the size of the cut out you need to get your drift into, unless you use the blind bearing puller, i'm sure the 748 one will look nothing like this, but the cut out might be the same size.
cheers
gogs
The 916 one looks exactly the same so I'm sure the 748 does too.
When I changed the bearings in my bike I enlarged the cutout to make it easier to get a drift in there the next time.
Thanks for the advice. Was going to replace the bearings with decent ones, bet the some of the ones on Ebay are chinese.
