748 Throttle body/ Inlet manifold gaskets?
Growler
About to head off on holiday for a week but plan on checking valves, replacing belts etc on my return. The bikes stripped down ready to go and having looked at it quickly this afternoon I see Im gonna have to remove the throttle bodies to check the inlet valves on the horizontal cylinder. Haynes Manual says to remove at the rubbers then remove inlet manifold on both vertical and horizontal cylinder.
Two questions really.. Can valves be checked by just removing throttle bodies? and if manifolds need to come off are the gaskets re useable or should I order a couple so they are here on my return? Finally if manifolds need to come off is it easier to just remove 4 bolts on each and keep throttle body assembly together to save disturbing the inlet rubbers?
Just loosen the hose clips on the inlet rubbers and pull off the throttle bodies. This gives you all the access you need with no need to remove the manifolds when checking the valve clearances.
[qimg]https://lh4.googleusercontent.com/-s7HF0XJiO9I/T_yEh2fsnrI/AAAAAAAAD60/5AlWYENea6Q/s1024/100_1621.JPG[/qimg]
Perfect... keeps it simple... Was reluctant to disturb rubbers if I didn't have to as I had a nightmare with inlet rubbers on a VFR400 a few years back! But if thats how its done then thats what I'll do. thanks Derek... ;)
