Someone who knows what they are talking about will be along soon but fuel filter, air filter, battey etc are all good but common to both cylinders, I would be looking for things specific to the problem cylinder. Slack or tight belts will effect timing a wee bit. Check belt tensions and valve clearances as a matter of course then probably ignition / injector / TPS / air leaks ....
