Controversial, but I just mixed my tyres for the first time and can report a vast improvement in grip, mid-corner handling and control on the exits.
I had a pair of BT016 which I loved. When the rear went and I thought the front had some life left, I replaced the rear like-for-like. However the front deteriorated quickly at the Manx leaving and the local bike shop only had Pirellis in stock. My brother had fitted SuperCorsa BSBs to his 848 that week and was raving about them, so I stuck a BSB on the front of my 748. I wondered if the ‘do not mix brands’ argument came from manufacturers as a way of making us buy a 2nd rear tyre to match the front, thereby squeezing another £100+ out of us?
Now, my argument goes like this – front and rear tyres have different jobs to do at different times, especially entering and leaving corners. Mid-corner when the bike is on neutral throttle without any change in lean angle, there’s less force being exerted on the tyre than when entering or leaving. Entering a corner on the brakes, leaning a little while still braking, then letting off the brake all puts massive pressure on the front tyre at different points whilst letting the rear merrily skim the surface of the road. A little gas to correct the angle mid-corner and the rear may over-steer a little whilst the front is pushed sideways and fights for grip. If the rear grips hard, especially as it will when exiting and as the bike begins to straighten up and the weight shifts to the rear, and the front may leave the ground anyway, or at least have less pressure on it.
Now I’m not advocating going mad on trying different tyre combinations, and it’s definitely up to the rider to make the final decision, but 2 tyres from different manufacturers (Bridgestone and Pirelli in my case) which are both designed for high performance riding could well work in harmony with each other. Equally, getting the pressure wrong by a few psi could be just as bad as mixing rubber (I currently run 33psi front, 36psi rear).
However, you could also argue that my totally goosed front BT016 tyre, with it’s flat spots at the 10-to-2 angles was causing me to run wide on the corners. And that the massive improvement in handling was not down to the deliberate mis-match of tyres but just because I spent £135 on a new tyre! In addition, the out-going front BT016 was 120/60 and the new BSB is a 120/70 which would also make a difference to handling.
(I've only tried the BSB in the dry so far, but I know the BT016s were absolutely fab in dry, damp and wet, really inspiring confidence)
Here's an idea - if you liked the tyre you were on, and it was not limiting your riding, then why not get the same again? With a nice round profile once again, it will undoubtedly feel better than the current one.
Hope this helps?!
S
