748 . . . . No Lights
Silver-Surfer
Help
My 748 has no lights !
Bike runs and everything works but no lights !
Instrument lights work but no side lights or main beam ?
Any help ?
Its a 1995 748 BiPosto.
Thanks
SS
Sounds like the switch gear maybe?
The kill switch on my 748 sometimes sticks in the 'off' position and take a few flicks to kick the fuel pump into life.
Does that mean you have a tail light and dip beam? Or do mean NO lights except for the instruments?
There are 2 different circuits involved so there may be more than one fault.
The headlamp - dip and main beam are supplied from fuse 3 to the headlight switch via a brown wire. Fuse 3 is live when the ignition is on. When the light switch is moved to the headlight position power is routed to the dip switch and to either dip or main beam depending on where the switch is set.
Fuse 6 also becomes live when the ignition is on. It supplies power via a light blue wire to the ancillary circuits - indicators, fuel level warning light, oil pressure warning light and neutral light, with a Tee off to the light switch. When park position is selected on the light switch this is then fed by an orange wire back to the ignition switch. If the ignition switch is ON, it continues via a yellow wire to the parking lights, tail light and instrument lights. When the ignition is in the PARK position the yellow wire is connected to a permanently live white wire turning on the parking lights and tail light.
The only thing that is common to these 2 circuits is the headlight switch and it's connector.
However, if the instrument lights are working then the parking light and tail light should also be working since they are on the same circuit.
I think you should double check the bulbs, make sure they are all fully seated in their sockets and make sure that any in-line connectors are firmly connected with no corroded pins. It might also be worth checking the big round bayonet connector that joins the front part of the loom to the main loom.
Great reply thanks.
Off to the garage again t check the bulbs, I would be surprised if they were all dead though ?
Rear lights work as do the indicators, horn, instrument lights, kill switch, oil light, neutral light . . . . .etc.
How far is Forfar from Dunfermline !!
Off out to the garage !
SS
