748 neutral light staying on
sam1176uk
Hi folks,
Tried a couple of searches but couldn't find as much as I thought I would, I have a fairly common (I think) problem:
Washed the bike last night and took it out for a spin today, the neutral light stayed on, it was slightly brighter when in neutral...
Any tips before I start fiddling about with it tmrw probably? Neutral switch looks tricky to get out!
Hey, mine did this last year but as i was only a month from getting it serviced i just let ducati fix it, im pretty sure they just replaced the box bit. Still does it now and then so think its maybe a break in the wire or something, doesnt really faze me though so i just leave it to do its own thing lol
Not much help sorry, but to my knowledge its common!
The neutral light has a single wire that switches on thew lamp by earthing it. If you follow the wire from the switch for about 18" or so you will come to a connector. If the light goes out when you separate the connector the fault is with the switch, if not it's a wiring fault. Almost definitely the switch has got water in it though and will work fine again once it dries out.
If the neutral switch is fecked I recall replacing the one on the old ST for less the £20, a little tricky to get out with a (I think 13m box spanner) but Derek advised it is only tourqued to 5 or 6 Nm so finger tight and a wee nip up will suffice...
