748 - Fogged up lights!!
Bullitt
Hi all,
Does anyone have any tips for getting rid of the fog that tends to build on the inside of the head lights?
It seems to more of a problem on the high beam side and most things I've tried don't seem to work....
I'm sure there was a thread before on this problem, but I can't find any sign of it!!
Thanks in advance.
Fraser.
Take the headlamp assembly off and remove the bulbs. Tip a couple of tablespoonfuls or so of methylated spirit into the headlamp unit and give it a good swill about. Empty the meths out and allow any remaining in the unit to evaporate then re-install the lights. I did this to a couple of headlamps off a VW golf recently and they came up like new.
Hi all,
Thanks in advance.
Fraser.
Stop deep washing the @@@@ every 2 weeks would be a good start! ;)
Good tip Derek. My Golf has this problem. I will try it at the weekend.
I will give that one a try. Just so happens I have a bottle of the stuff in the flat...
Cheers!
I just stuck a clean rag in through the bulb hole & poked it about with a stick until all the glass was clean.
Has anyone got any recommendations for bulbs btw. I've got through about 3 or 4 filling station dip bulbs in the past year. Earths & connections all good. Suspect it's just cheap bulbs & bumpy Scottish & Irish roads but you never know.
ShedBob :confused:
ShedBob :confused:
Lidl had some in recently.
Well - the flat now stinks of meths..... but the headlight unit is a good bit cleaner than before!!
I've never had to replace any lamps in the duc btw ShedBob - had her almost seven years now :eek:
Cheers folks!! :flash::flash::flash:
Common problem that. Done the same on mine as well. Going to do the meths clean up, might have a dram of it while I am at it. The jakies seem to enjoy it round my way.
