748 exhaust cleaning
ibgarrow
My SPS exhaust is badly discoloured and rusty. Before I set about it with a wire brush, is it coated with anything special? Will I be doing anything silly if I put a wire brush in a drill and try to clean it up?
The exhaust should not be coated with anything, should just be raw stainless steel.
Only if you use anything other than a stainless steel brush. For some reason, I'm sure someone can fill in the blanks, a coating of the brush metal ends up on the pipes. I initially used a copper brush on a Dremel, it got into all the awkward place but left a "golden" coating. Quickly bought a S/S brush, job done.
Before:
Nearly after:
After:
