My MOT ran out on the 23rd and my rear brake has stopped working again! I spent ages last night bleeding the bleeding thing and got it so there was a bit of pressure when the pedal was pressed. I book the MOT for tomorrow afternoon and I check the back brake this afternoon and the pedal has no resistance, goes down really easily and there is not much movement on the brake pads. Back to square one. I fitted a new M/C last year as it didn't work then, I took the caliper off, split it cleaned it up re-assembled it and now having done 5k since the last MOT it's packed up again. Or has it? I pumped new fluid in with a syringe from the bleed nipple as Mike suggested and I think I got all the air out cos I spent long enough doing it! So is this the right way...........pump lever several times and on the last one push well down, open up nipple with tubing attached, fluid goes up the tube , close nipple and gently release the lever. Repeat and repeat again and again etc
