748 biposto engine water temp sensor for computer
taminator
hi there, has anyone got a water temp sensor for a 748 biposto 1996 the one that tells the injection system to alter the fuel mixture ,have ordered one from ducati glasgow but not sure how long this will take as its the factory holiday in italy, bike running like a harley farting and popping all over the rev range, would appreciate your help my number is 01505343436 cheers tam.
Take the old one down to you local motor factors. I'm sure it's the same as a Fiat Punto and will cost you buttons for the same part from Ducati
water temp sensor for injection
thanks everyone for your help , i will ltry and see if a punto sensor is the same . just while im here if your replacing the bearings in the rear hub axle 748 916 series i have the part numbers from BSL and the lot cost me 25.00 quid ,cheers the taminator, in fur a penny .:
