600ss cam belts
snoopsmydogg
Looking for a little advice folks.
I am going to be changing the pistons on the bike this winter and have been told it is a good idea to replace the belts while I am on. They were last changed late 2007 and have only done a few hundred miles since.
I was told that once you take belts off you shouldnt put them back on. Is this true? Can anyone point me in the right direction where to buy some?
Cheers in advance :)
The belts are well within the 12,000 miles or two years limit. You can take them off and put them back on again with no problem.
When you take them off mark each belt with it's direction of rotation and whether it is from the horizontal or vertical cylinder. As long as you put them back in the same place that they came from, in the same direction and properly tensioned they'll be OK.
I take the belts off my bike every winter (approx 6,000 miles a year), measure the clearances and whip the cams out to check the rockers and put it back together with the same belts, changing the belts every 2nd winter.
...don't ask BnP, he just doesn't bother - amazing that bike's held together!!! :rolleyes: :p
Thank you Derek, I was a bit concerned about re-using old belts. I will be taking them off this weekend and it's going to be at least a month before they go back on (replacement pistons should be arriving around christmas time) :) .
Ed :rofl: you have just brightened up what was looking to be a miserable morning :thumbs:
