2v Cam Nut Special Tool
monster_998
In the Project SuperSpurt thread, there was a PICTure of the special tool with the 4 spigots to fit the 'special nut' on the end of the cams.
Can anyone recommend a supplier?
In the Project SuperSpurt thread, there was a <a href="http://www.ducati-upnorth.com/forum/showthread.php?11851-Project-Superspurt&p=178309#post178309" target="_blank">PICTure</a> of the special tool with the 4 spigots to fit the 'special nut' on the end of the cams.
I got mine from an eBay seller in the US, I'll see if I can dig out the details. Remember you will also need the tool to hold the pulley while ypu are undoing the nut.
Different types of pulley?
Some nice bits there, along with comedy prices! Notice theirs holds the teeth of the pulley - one of my engines has 'bare' pulleys per their photo but the other has lips on the edge of the pulley that as well as making belt changing a right pain would also prevent use of this tool.
Maybe the lips can be removed though (of course they can, but I mean without a lathe..) I haven't given them much of a look as I will be changing to adjustable pulleys anyway.
255.1.014.1A : Timing belt roller x 2
160.1.076.1A : Flange x 2
852.1.124.1A : Special washer x 2
771.5.040.2B : Screw x 6
72944.1542 : Elastic-stop ring nut x 2
(Cheers to Derek for part #'s)
If the adjustable pulleys come with lips then I will look at howking them off.
The adjustable pulleys don't have rims (lips) and your older pulleys don't need them! :D
Howk them off with a pair of slip-lock pliers. You won't regret it when you come to fit new belts. :)
Saw this post and thought don't need these tools although I had saw the one on fleabay for £9, as I have a set that was made for my Pantah 25yrs ago will use them, went to use them on Sunday to strip the heads ready for blasting. Those geeks have changed the o/d of the castleated nut why the freek for? Same thread and you can use the pulley's from the ss monster range if the Pantah belt profile becomes scarce. :confused: Bought one from fleabay and made a tool for holding the pulley, mk 2 pictured tried a single bar but it bent, heads now at the blasters for a clean with coconut shell prior to painting.
