2piece front disc is loose
The discs are semi-floating. You should just be able to rotate the bobbins if you jam the tang of a file through the hole in the centre and turn it. You shouldn't be able to wobble the disc about, although some people have loosened off the bobbins to make "fully floating discs". It's all a question of how loose. It's OK for the disc to have a mm or so side to side but there must be NO radial movement. The rivets through the bobbins can be tightened with careful use of a hammer.
