2003 ST4S battery drain
ratchet
Bit of a problem with battery not holding charge, new battery last year, currently removed to allow full charge as no garage etc at moment.
With Ohms meter connected to battery connections and ignition off I am getting 0.073 meg ohms of resistance, which seems a bit low, but if fuse for display removed resistance drops to 0.486 meg ohms, which when isolated is down to the imobiliser LED as have disconnected with fuse in place with same result, could anyone confirm if this is the same as theirs or confirm if this is correct, as I don't have an amp meter to check draw once battery is charged. Unless anyone has any other ideas as to cause?
I also have a 2003 ST4s and the battery on mine will stay charged for weeks (although since I use it most days it's hard to find that out :lol2:)
0.073 MΩ (or 73KΩ) will create a drain of only 0.16mA, assuming a nominal 12V at the battery, which is tiny and should cause no problems with draining the battery. Unplugging the LCD will remove the clock from the equation and the increased resistance of 486KΩ will draw a miniscule current of only 0.025mA.
The only real way to check any battery drain is to connect a multimeter set to read amps between the battery and either the ground or positive cable.
Although it is a recent battery are you sure it is charging OK? With the engine running you should see at least 13.6V at tickover and over 14V at 2,000rpm and greater, probably more like 14.5V.
Next time I'm under the fairings I'll try to remember to check on the battery drain current but in the meantime I think you'd be better off buying a cheap multimeter so you can check what's going on.
I never had any probs till last year, to be fair never really did much with original Ducati battery, use all summer, store for winter and maybe give the odd boost charge if at all through the winter, charge up for start of year then a whole summer of running no problems, after 7 years did not think too much when battery gave up ghost last year, and got another from Harry, all be it not a Ducati one, but Harry's not known for selling dodgy parts :lol2:, but still waiting on charger running its full cycle (Hein Gericke one) which should give a battery condition check at the end, could be a faulty one, but given lack of maintenance over winter don't fancy my chances of a warranty claim, as battery tester will no doubt show up lack of care :banghead:
By the way thanks for working out approx amp draw, not even got mot on it yet this year, so not run for charging to likely be an issue yet
