2002 748r standard slipper clutch
vernon
hi there, can anyone help with information on how clutch plates should be installed as there appears to be no sequence available, at the moment there's a steel plate then spring plate,friction plate and so on , the last plate is a friction plate then pressure plate however when the clutch is pulled in the last friction plate is almost out the cradle and does not look right, also the old pressure plate was bad worn , can you help cheers ???????
You must start with a FRICTIONplate and end next to the pressure plate
with a STEELdrive plate.
If you had a friction plate last next to the p/p it would have given the p/p drive plate face a hard time.
brian.
