2001 996 Bp Front brake light switch not working
Adi
When I pull the front brake lever, the brake lights don't come on however when I depress the rear brake lever, they do.
Checked the operation of the front brake switch with an ohmmeter and it makes and breaks the circuit.
Then checked the bayonet connections from the front brake switch to the fuse box with a voltmeter and ignition on, 12V+ reading so power is there. Which is to be expected (as according to Haynes wiring diagram) it's on the same circuit and 7.5v fuse as the rear brake switch and horn which work.
Haynes doesn't mention a separate relay or fuse elsewhere on the brake circuit for the front and back brake switches so I am bit lost as to why the back brake switch and horn works and the front switch doesn't?
Thoughts greatly appreciated.
The front brake light switch output (grey/red wire) goes through the big 21-pin connector that joins the front loom to the main loom. Maybe the problem lies there.
  • Like
Reactions: Adi
