1995 900ss Oil Return Lines
mossy73
I have searched here and on the web for a supplier for these oil lines. I here they are a larger bore but it matters not!
the only outfit quoting these i have found is Goodridge:
Hi,
2 hoses made up of:
0.39 metres stainless braided hose
3 x straight fittings(alloy)
1 x 45deg fitting(alloy)
£100.00 delivered.
The 45* fitting sounds alarm bells, probably for the front pot, but will they really deliver what's required?
In short: who and where can supply quality items, what must i quote to get what's needed if having specials made up?
Apologies if im repeating old ground here.
Many thanks,
Chris.
OE ones from a dealer? They were dearer than I expected but way less than £100.
Cheers Guys,
I have a Pirtek acc and with another Hyd supplier, its what's the crack with orifice size and what to ask for is the dilemma. unless an after market hose supplier is in the know and can produce. not found one yet!
I read OEM was discontinued and im not one for believing web stories, guess i was just happy to swallow that one as BZP finish is not what i want, seeing as this bike will be naked.
Shall give HEL a ring today.............
Chris.
HEL do supply them for the M900- usually as part of the oil cooler line kit.
Same engine as SS
So might supply that part of the kit
Checked the site Sam suggested. They do for the Monster
Oil feed kit.
- Part no. OL1401
Given that a M900 has same engine as SS900, try asking them.
