I can't believe I did this, but maybe someone can help. I treated the bike to a new battery yesterday - the same make and model as the old one. After fitting the new battery I tried to start it, but no response except the dash lights were on. After checking, I noticed that the polarity of the battery terminals was reversed compared to the previous "identical" Yuasa battery. Doh! After reconnecting the battery correctly I tried again. With the ignition on all seems normal with the fuel pump working, etc, but as soon as I touch the start button the 15 amp fuse blows again. Looking at the wiring diagram I suspect the problem is with the starter relay (item 32), which I will check by bypassing it manually. As I am relatively new to the bike can someone tell me if my suspicion is correct or should I check something else? Thanks.
