I have a 1974 250 single which I am renovating.
Bought a new samarin 30mm crankpin kit and new piston for the bike, (Lacey Ducati) I have fitted new SKF C3 bearings in the cases. Tried puting crankcase halves together with just a new gasket and no internals, fine, put in the rebuilt crank and closed the cases, fine, bolted the cases together and checked the end float on the crank, =1mm. I have two old shimes of .53 and .32mm that were fitted before.
Fitted the .53 shim to LHS and the crankcases wont fit together cleanly, it rocks slightly around the crank, same with just the .32. tried the shims on both sides and RHS only, same result, case will not close (about 1mm rock)
As a test I gently and by hand only, put in a few bolts/screws and as expected the crank was more difficult to rotate so backed off and removed all shims.
I have just ordered a set of crank shims from Lacey Ducati (was going to measure what I needed then order later) Mr Lacey says this is a fairly common issue and is likely crank shim related, will find out as soon as I can fit the new shims.
At Mr Lacey's suggestion I checked the original shims, they sit flush on the new (fully seated) bearings and on the crank shoulders, though they are a bit larger diameter than the crank.
I can't see why the original shims can be causing this but they are, or are they showing up some other defect.
This is the original crank (new pin) and original cases with new bearings, my bike is a very original complete machine.
