1198SP Track Suspension Setup
Bullitt
Hi all,
Fairly simple on the face of it, but I’m needing some assistance on with the suspension set up for my SP, purely for track use.
I’m a total suspension novice and I had taken on board some of the suggestions of guys at the track that seemed to know what they were talking about and it is handling better, but there is one corner at the track I go to, where the thing just handles like a dog, give excessive lateral oscillations to the point where I have to back off the power to regain control…
From speaking with Martin at DG a while ago, the bikes are set up very soft at the front and too hard at the rear so I’ve tried to solve that problem, but I still have almost full front compression and the rear just doesn’t feel at all happy! I’m not that heavy at 78kgs, so I think something is a miss….!
I’ve got the basic details for the forks/rear shock from Ohlins ,so I’m using them as a basis to get some understanding of suspension, but my knowledge in this black art is very limited.
Unfortunately, my local “dealer” is not the best and such help would fall on deaf ears with a blank look of, “eh?”
I have had a good look over the various links in the Tech Library and they are helping my understanding too.
So, are there any secret suspension guru’s out there that can help me find my ideal setup for maximum track fun, or give me some pointers that I can work from??
As a start, the following I guess is useful:
My weight – 78kgs
Rear Ride Height raised approx. 15mm
Tyre Pressures; 30F/28R
Thanks in advance!
Fraser
Okay, thanks again to Mart at DG - certainly helped with my understanding on a few points.
I have decided to start experimenting - eek, NO I hear you all cry!! But, this will probably help me understand how suspension works.
First things first, Tyre Pressures
... It's "cold" outside today and the bike hasn't been ridden. So,
F/28
R/26
Recommendations for road use are 30.5F/32R
A thread from the ever knowledgeable Shazaam suggests track pressures should drop these by 10/20%F/R less than standard for track use (more work, more heat, more pressure) so these figures make sense!!
I should measure the cold/hot ratio using the 10/20% method for front and rear. After a few laps on the track, I should see an increase of not less than 10% in the front and 15-20% in the rear – 31F/32R…
So, some thoughts on setup – after reading a lot of info….
Front End.. (Ohlins FGRT Series)
Standard settings and changes
Preload (std 8 turns), increased by 2, max is 15
Rebound Damping, (std 10 clicks), increase by 2 clicks, max is 25
Compression Damping, (std 8 clicks), increase by 2 clicks, max is 32
Rear End (Ohlins TTX)
Preload, unchanged
Rebound Damping, (std 14 clicks), increase by 5 clicks, max is 22
Compression Damping, (std 14 clicks), increase by 3 clicks, max is 22
If there are any of those out there better informed, or if the above seem utter tosh, do tell!!
Thanks again!!
hhhmmm..that rear pressure would be uncomfortably low for me ...30 front 30 rear is what you should be running
you need to remember that the air pressure is one of the main forces keeping the tyre on the rim!!!..
unless your running dunlop d211's ntecs then id try 30 30 first and see how it feels
stronger spring at the front, make it do more work and fine tune via the adjusters......................or just MTFU and give it full gas everywhere.
Spring should be okay, I'm no fatty!!
I do give it the full beans - therein lies the problem... twitchy!!
