1098S Rear Brake
Beano
Gents,
I have a 1098S and the rear inside pad had worn right down and the outside pad is fine,I believe the piston is sticking ? and secondly how do you change the pads ?? and would I need to bleed it again any help would be great thanks
pads can wear unevenly even if the pistons are free, how many miles as the bike done? if its not many it does suggest that the pad isn't retracting, is there a lot of friction when you spin the wheel?
it might be worth cleaning the caliper up anyway, pistons can get muck built up on them which prevents them retracting. the only thing (other than a warped rotor) that pulls piston back is the shape of the rubber piston seal, it extends as piston pushes pad and has to "grip" the piston to ring the piston back in, obviously piston needs to be low friction to go out smoothly but then needs to be grippy enough for seal to pull it back and wear/muck all effect this.
most pads are removed by unclipping pin circlip, pulling or unscrewing the pins and sliding them out but i ain't done a 1098 so don't know exact method, you may need to remove rear wheel to get at it.
Never swap them round, doesn't solve the problem, just delays the inevitable.
That vid is @@@@e. He's using the wrong tools badly, you can't see much for his bloody hat in the way and he doesn't explain it at all well.
My 1098 has done 13000 mile and rear pads are still as new :D But Gizmo is right, they need to be cleaned occasionally. A can of brake cleaner costs about a fiver and could do the trick. It will lubricate the rubbers and disperse the dust/grit build up. Maybe no dismantling will be needed at all.
Every winter I unbolt the calipers, one at a time, and remove the pads. I apply a clamp on the piston(s) on one side then gently squeeze the lever or apply the footbrake until the free piston(s) is a fair bit out. Obviously care is required that they don't get pushed out altogether. I then clean the pistons with brake cleaner and apply a smear of red brake grease before pushing the them in again. I then repeat the process for the other other side of the caliper. Doing this once a year ensures that the pistons don't seize and that the pads wear evenly.
Don't entirely disagree Pete but can you find one better or even post an exemplar?
Many thanks for all your info and helps guys,it was quite an easy job to replace and the caliper has been cleaned but was already in very good clean order,but still can't understand why it had siezed up
Mmm, a bit strange this one. I wouldn't have thought the piston would have seized on such a new bike, Brembos are usually very good as they are anodised after machining. I have seen some seriously grotty bikes where the pistons have pushed back in easily. Did you check if the pistons pushed back easily enough? If one of them doesn't I wonder if a seal might have got dislodged during assembly making it tight? Doubt it but you never know!
Don't think bleeding will resolve it either.
Possibly a tight pad, were they slack enough in the caliper?
Hope this helps rather than adding to the confusion
Good luck
Ducati John.
www.ducati-john.co.uk
