Well thank goodness for that, it started right up and everything worked.
I’ve done a bit of work on my 916 over the winter. Fitted mono subframe and loom, fitted new slightly higher bars, replaced my dodgy cam followers and set all the valve clearances, replaced all the fuel lines, connectors and filter, did a full service and replaced the cam belts and replaced the top half of the front forks to get rid of some corrosion.Today it started first time and no leaks so far!
Now time for an MOT
Now time for an MOT
