Flatline
I thought you might like to see that I do own a Ducati!
This is my first attempt at building a bike
The donor is a 92 J plate 750ss on 16k miles
First thing was to strip it down, the engine was stripped and painted with black heat resistant paint
As this is my first project I decided to keep everything as simple as possible
No fancy colours, no engine modifications apart from filter changed to MWR and any jetting required
Here's the frame just out of the oven
Swingarm........
Spring..........
and wheels
Now to start the rebuild
I have fitted a scaffold pole through the walls of my office/workshop to support the bike using a strap
As you can see, my first mistake was getting the frame powdercoated before I have sorted the rear and removed any brackets
However at £40 I thought it cheap enough to get it done again when everything is sorted. And I may want to change the colour anyway
The tank has been stripped, and I have made a fiberglass rear pod
If there is any interest I will post a thread about making the pod
This is a trial run to see what it's like and also practice as its the first one I have made
All they alloy parts have been blasted and will eventually be anodized
That's were I am at the moment
Things that need to be done:
So, there you go
I will keep updating as and when I have done something
You can see more pictures here: http://imageshack.us/g/163/pa241532.jpg/
Swingarm........
Spring..........
and wheels
- I have a monster loom so that needs fitting and the connectors changing to fit
(Anyone local able to give some pointers on this?)
- Get some brackets made for the single round headlight
- Strip and service the forks
- Decide on a tail light design
- Ditto indicators
- Design and make (or get made) a speedo bracket
Or perhaps get one from another bike (not a monster)
- Find out how to fit a different speedo. What's all this about ratios?
So, there you go
