Wheel bearing spacer lengths.
Serious Black
I've just picked up a set of 900SSie wheels cheap. The catch is that they came without bearings and spacers. Would any nice kind soul have a set of wheels with the bearing out be good enough to measure the spacer length?
Not that hard to do yourself surely? Just measure the distance between the inner lands where the bearings sit? Or is that too simple? I think it's less than 100mm so should be easy with a standard vernier scale.
The problem is getting a set of calipers in th hole. The solution looks to be buying a cheap set and grinding bits off so they fit. The back spacer is about 150mm long.
Buy a cheap pair of digital calipers
they have a depth gauge built in and they are easy to read
