What oil ?
dseered
I know it has been done to death, I just want a quick answer, Fully Synth, Semi Synth, Mineral ????
And what weight, my mate has quite a bit of Shell Advance at his house, cheap !
Many thanks !
I use that Motul stuff that they recommend and sell at Ducati Bradford. Is it semi-synth? I believe so. Works well enough, but Shell is good too - esp if cheap! But I thought you were SORNing it?
Don't need road tax for trackdays !
in which case, will you need to re-consider choice of oil anyway? You may need different weight and type, 'cos presumably you will be changing it more often. just a thought - ask some racery type guys, they'd know better.
Got Motul 300v in at the mo' 15/50 IIRC fully synthetic.
brand doesn't matter too much IMHO, but maybe fully synthetic and xx/50.
is better for track use in the hot weather that seems to have gone!!
xx/40 is OK but can go a bit "thin" when the bike gets really hot.
Ducati recommend shell, current sponsors of the MotoGP team.
Just make sure its Bike specific tho'
Ray.
Many thanks !
Definately not vegetable oil! ;)
Until relatively recently the only oil to choose for racing was Castrol R (remember the wonderful smell) and guess what that was made from? - Castor oil!
Ile
Get the viscosity right and use pure mineral or pure synthetic, preferably the latter. There used to be a great article on the web on how certain viscosities are achieved by adding modifiers which are bad news NB never use slick 50 etc EVER as they can cause damage and is why the manufacturers don't recommend them, even tin box ones. Semi synths are also to be avoided due to this, in the USA certain semi synths in certain viscosities will lead to warranty withdrawal in the US.
Apart from that change the oil lots more than Ducati recommend, 3,000 miles minimum - especially if you have a wet clutch model - bit like cleaning your teeth with your bath water really...
