Upgrade Starter Motor Cables.
KeithW
Anybody any experience/advice on upgrading starter motor cables ? To make the starting of carb/belt 900's less problematic.
I didn't do the starter but I did do the earths. Past experience on other bikes plus Ducati's dubious reputation for electrics. Mine starts fine with the standard starter cables. Might change them in the winter.
Am just away to do starter etc and earths on the 944 project, Vehicle Wiring Services welding cable. Will post all the details shortly.
not so sure its the actual cable but the connection at the starter that can be an issue
And the earth connection to the engine. In fact on the carbed models the battery earth goes to the frame and there is a further earth strap behind the RH footrest hanger connecting the frame to the engine. All of these joints offer potential resistance.
I used the ‘Powerlet’ option, it made no bloody difference at all!! And, I have two earth cables. My advice is clean all the terminals and if your cable is not knackered then use that, and save money towards a good battery.
Keith, are you having issues starting the belts?
Assuming you are given the post?
No particular problem starting at the moment, just though I might add the upgrade of the starting cables to the list of tasks during the winter service of the Superlight. It may just be a case of "they all do that sir", but for a fraction of a second from cold there is a bit of a "hesitation" before the starter turns and the engine fires. It may just require all the contacts cleaned and tightened. I appreciate all the sound advice, thanks
