sam
Seeing as the wee Duke will become MOT exempt this year I thought I would upgrade the brakes a little. I picked up a CB 350 k4 brake plate on fleabay for a fiver seeing it needed a wee repair to one of the actuator pivot points. I machined out both and inserted bushes.
I also removed the speedo drive and blanked that off. The plate had a different offset so I turned up a spigot to fit where the wheel spindle passes through bored and tapped countersunk the end and then split the spigot using a hacksaw, by using a countersunk screw this opened up the spigot gripping the brake plate. All done hopefully this will give a bit of better stopping power.
