The temperature readout on the display suddenly only displayed 3 flashing - - - . I cleaned up the female spade connector and all was well for several months. Then, the readout would go from LO to, say 43, then 45, 55 then back to a flashing LO and the cycle would repeat ad infinitum. I put the thermistor (this is the temperature sensor with the single wire connection on the bottom right hand side of the oil cooler as you are sat on the bike, the function of which is to give you the engine temperature information on the clock display) in a pan of water on the cooker and heated it up. It started off at nearly 1k resistance and slowly went down and then the needle was all over the place before going back to 1k and the cycle repeating, so basically, the same as it was doing on the bike. Checked with Ducati and a replacement part cost £39.06 inc VAT! Not happy with that I started to scour the web and purchased a replacement from VW vintage car parts, Volksbits, off eBay for £5.39 inc vat & free delivery!!! The part looked exactly the same and the thread size of 10x1 metric sounded good so I risked it and found that it fitted perfectly. Now, from cold, turning the ignition on the display immediately reads 40 and not LO. As the engine runs and warms the display rises and I let it get up to 100 before switching off. Unless anyone comments otherwise, I will assume that the engine temp is 40 degrees less than the display is telling me. I have never seen my engine temp read over 102 and the max temp before a warning display is, I believe, around 171 degrees C. Hopefully then, no foreseeable problems unless you tell me otherwise. We are off round France & Spain in a couple of weeks so will find out for sure, might even get the genuine part cheaper on the continent. (Replaces ORIGINAL VW PART numbers:
049919501, 049919501A, 049919563A, 027919501 or SE0219470001.
Thread size 10x1 metric.
Imported from EUROPE stocked in the UK.)
