Surface discharge spark plugs
Benjie68
hia y'all....ust wondered if anyone had tried/tested surface discharge plugs...theory/advertising points to a better burn, and bit more power as a consequence, but if theyre so good, why doesnt everyone use them? :confused:
My old girl has to use them due to the piston/plug clearance in the tuned motor and one bit of advice is: if your fuelling is not absolutely spot on (as mine wasn't) and it doesnt start after a couple of prods of the button, they get soaked in fuel and you might as well go and have a cuppa and forget going anywhere for an hour without taking the plugs out to dry!
Thanks guys...well have bought a couple so will try them out...have kept original chip in on Termis to get a lean burn (for the time being) so might be ok on plug wetting....anywaiz, it is 11 yrs old, so plugwetting days shd be over!:D
