Sticky Starter Motor?
Aaaah that Ducati sprag clutches brings back memory's , The Bosch Ignition pick ups on the Darmah used to move when the engine got hot (someone failed to mention to Bosch that the pick ups would be sat in hot engine oil and the front cylinder down pipe would be less than an inch away :rolleyes:) throwing the timing out causing the bike to backfire on start up which would sometimes totally destroy the sprag clutch and deposit the remains into the sump :eek: In my ignorance I assumed the starter motor was dead so just kick started the bike and continued running it , Result was one totalled engine as the bits of broken sprag bearing circulated round every part of the engine :( The second time it did it I dumped the oil , binned the electric start and fitted a 900SS clutch cover .
Glad you've got the bike sorted Steve and go on admit it , Theres a certain perverse pleasure in fixing it yourself ;)
hi b&p
check the flange/gear in your pic for 2 tracks running round the inner face========bit like that,and gear no20 IIIIIIIIIIII like that, more so gear no20 it should be smooth the clutch may still slip if it has IIIIIIIIIII, you will see what i mean if you hold it to a light (shiny dull shiny dull):)
brian:comp2: :)
hi b&p
brian:comp2: :)
I gave the gears a once over but wasn't really sure what i was looking for except abnormal wear, missing teeth etc, will have another look tomorrow, cheers
cheers, getting a new one from John Cellier for £70
[/QUOTE
I had a Darmah in the 80's too. Lucky for me I never had the timing back/fire issue. :eek:
I had it for about 8 years & the only thingthat I can remember breaking was the sprag clutch.....& I'm sure 20 years ago it cost £55!!:( :confused:
Is John Cellier "Ducati John"?
hi b&p
brian
the inner flange is fecked too, like you said, well tracked! the gear actually looks ok, minute bit of scouring but certainly reusable, however Ive got a complete sprag / flange and starter gear on its way up from down south for £80 + p&p :)
might be out on Sunday afterall !
picked up all the bits today, all fitted tonight, just need to check over tomorrow then put all the fluids in and connect up the electrics and hopefully BOOM BOOM! :D
nah, but if it doesn't go BOOM BOOM it will be going GLUG GLUG in the Aire and Calder canal!
Hi hon, still no luck with bike then? mate of mine tried dumping dead bike into a river, until local plod told him to retrieve his bike from the bottom! Copper was stood behind him when he pushed bike over into the river, DOH!!!!!!!! :doh:
Well...................................................
a pic showing the damage to inner of flange and to gear, just incase anyones interested...
quick update, took the bike out on Sunday on the DL rideout, on the way to DL (9 miles from my house), bike was running at 100 - 105 deg at 70+ mph. Quick check on the water level (cheers davie ;)) no water dispite filling up with coolant after re-assembly. popped a litre of water in at DL then headed off for the Lakes. No water showing at Ravenglass but temp guage didn't rise above 70 all the way, added another litre of water at the snap shop. Got home to find no water showing again, topped up with litre of coolant tonight and rode it briskly to Squires and back and just as much water in system on return as when i sat off :)
Big thanks to everyone for replies and advice, my bike is running like a @@@@in dream and im chuffed as @@@@ I fixed it myself with a lot of help from you guys (and major thanks to Ducati John for borrowing me the tools to do so)!
see yas at MM :) :) :)
Good to hear it's all sorted now Steve :)
Sounds like the cooling system was airlocked, they can be a right pig to get all the air out when you're re-filling it. I find it best to fill up to the radiator cap and then repeatedly squeeze the radiator hoses so that the air "burps" out. Keep doing this until no more air comes out and then put the cap on and fill up the expansion tank. It helps to do it with the bike on the side stand so that the cap is at the highest point of the system.
See you at the MM :)
Cheers, figured it was airlocked, must remember to 'burp' the air out with the hoses. Was mildely concerned at it taking onboard 5 litres of water and seemingly not leaking any, guess it must have been blowing it out the overflow while riding? Ran it up to 100+ deg in the garden 2x testing for water or oil leaks.
All sorted now though :)
