Possibly the crank sensor. When you switch on, the ECU turns the fuel pump on for 3 or 4 seconds to pressurise the fuel system then turns it off. When the engine turns over the crank sensor send pulses to the ECU which then turns the pump relay back on again as long as the engine is turning. It also uses the crank sensor signals work out the spark and injection timing. The fuel pump, injectors and coils are powered via the same relay, so if no crank signal - no sparks, no injection, no fuel pump except at switch on.
Apart from substitution the only check is; does pump relay engage while the starter is turning? Also can you see if the revcounter needle is flickering? The sensor should have a resistance of approximately 680Ω
