St4s bars revisited / Adjustable head angle
iconic944ss
Still not happy with the bars position on my ST even with super high risers fitted.
So an Ebay search I had set running, spotted an unusual setup being sold in Italy from an S4Rs:
It ticks lots of boxes for future projects as it has inserts for the lower clamp for using Ohlins forks with but the unusual parts is that the head angle is adjustable via an eccentric
insert in the upper clamp.
It comes with caps to fit over the over Fork tops and CycleCat high rise clipons.
Even better, I got the WHOLE bundle for less than the cost of a set of new cyclecat bars!
Of course, there has to be a downside - I'd hoped the caps would be a direct fit onto the ST but sadly, the spacing is wider for the bolt holes so I'll either have to modify my own riser spacers or fit the top clamp ....
There could be some long nights in the garage ahead ;)
I'm surprised that the caps don't fit, I thought the ST and Monster bars and yokes were interchangeable. Looks like you'll be fitting the whole top yoke then :D
It's not a big job :)
I've only visually measured them against the paper template I posted previously, but the monster bolt holes do look to be about 5mm wider apart than those for the ST :confused:
The fairing is coming off soon anyway Derek, for a few mtce jobs - I'm guessing that Ducati fit ball bearing head bearings on the ST rather than taper rollers?
Seems Cyclecat are back in business as well:
http://www.cyclecat.com/bar-mounting-systems/item/69
I think you'll find that they bolt straight on. I see you've got the full Cyclecat bar set, very nice. I only have the caps and they are copies but I'm using them with fully adjustable Apex riser clip ons and they work well together.
Yes, cup & cones with ball bearings. I replaced them with tapers although the bearings that came out were fine. The taper bearing is a Koyo 32907 JR2
Finally got around to trying the caps on my ST at last & I'm very glad (for once) that my measuring abilities were poor ;)
Cap fits a treat! Amazingly, on the highest setting the cyclecat bar is only a single cm or so higher than my 13mm plates I made, following Derek's design.
But of course, I can alter the angle and rake of the actual bars now to try and get exactly the right position, hopefully.
