St2 Alternator Replacement....some help..?
Curriedug
I have taken the left-hand side casing off that houses the alternator.......now its the wiring bit:eek:.......and I need to make a connection to the original connector that goes to the regulator/rectifier and would like to make a good professional job of it!?:p
Any suggestions welcome...........pics below of the old and the new parts.
I have to say Ducati Forfar did well to describe to me how to get this far. Thanks Derek.
Another friend has suggested soldering the connections together then using heatshrink over the connections to form a waterproof seal? :dunno:
Whats the verdict out there?:confused:
If you are good at soldering do so by all means, many people solder them to do away with the crappy connector the Ducati fit, but remember if you need to need to change the regulator, remove the alternator cover or take out the engine you will need to unsolder it again.
Yip....its also a tricky spot to get in to between the frame and cylinder head to solder/ unsolder the 2 wires!! :rolleyes:
..............and successfully tested and charging:flash::D
\\\\\\\\\\\\\\\...road test and no oil/ water leaks:)
....so ready for the Highland Fling:D
That's a fine collection of hammers you've got there Doug!!
Yip...the rubber mallet is for the initial gentle approach to removal/ replacing.....and the hammer is handy for the......right ye little b@@@@@d approach!! :lol2:
......................when required of course!!:D
Is this your mate???
