Solenoid - a Ducati 748 with electrical issues? Really?
Jared Earle
My 748 broke down today. At 70mph on the motorway, the engine just lost all power with what was obviously an electrical fault. My roadside rescuer checked it out and it started a bit then died. Just unpredictable typical 1996 Ducati 748 electrics.
Once we got it back home, I got my multimeter out and the mechanic started it with a 50p across the solenoid contacts, so at the very least, w know the solenoid needs replacing.
Once it's running, everything is fine, but I don't think I'll be riding down to Silverstone for the GP next month.
Anyway, to bring this tale to its end, anyone know which solenoid I need? I'd rather not get one from a breaker on eBay, so I'd prefer a new one.
Doesn't sound like the end of your tale - sounds more like the start of it. What caused the breakdown on the motorway? - can't have been the starter solenoid...
As Hindsight says,just the start,my 748 wouldn't start after a run,just the usual "clicking" at the solenoid,feared the worst(having to remove starter),but then remembered a wee trick i was shown/taught by a club member-check the wiring going into the relay,it's got 2 wires moulded into a small plastic cover,gently force them out and clean all the terminals,making sure they engage back in securely,that was the problem with mine(along with a broken wire up in the harness),so i check everything with the wiring now,taking my time-hope it helps to get yourself back on the road-Graham.
It would be very difficult to give a diagnosis from your symptoms as there are a number of things it could be and as Hindsight says the starter won't stop it going.
First, check the connector at the back of the solenoid they are known to fall out.
There are various reasons why the bike could have cut out but I would start by checking the relays down by the battery for corrosion on the terminals. One of them is the main relay and if it fails all the electrics will cut out. The other two are the fan relay and the flasher unit, neither of which will affect the running of the bike.
Under the seat are another two relays, one which supplies power to the ECU, the other to the fuel pump and coils. If any of these fail the bike will cut out. Again check them for corrosion at the terminals both of the relay and in the socket. These two are interchangeable but either one failing will produce a similar fault. The early bikes have fuses built into the relays and the fuse socket can get corroded and provide a poor or intermittent connection.
You should also check the big round connector at the RH side between the main loom and the fairing loom for corrosion of the pins as water may have gotten in. Similarly the smaller round connector to the throttle bodies and injectors, although bad connections there would more likely result in a misfire than the engine cutting out.
I hope that's given you a few pointers. Although there could be other reasons I think these are the most likely.
I do realise that the solenoid dying is more likely a symptom, but with a new one, I can at least ride it to the Ducati garage, and if it breaks down on the way, get it relayed there for free. :)
Groan :rolleyes:
Have you been getting humour lessons from Borderduc :D
