eonan
Can anyone help with a wee electrical problem I'm having. My problem is that I know jack about electrics
I've put a new stand on to the Monster, an SBK style one, so now there is no place for the sideside stand side of the wiring to go...so I've just taken it right back to the connector.
At the moment, I have a small piece of wire connecting the two sidestand switch wires...shorting it and allowing the bike to start with stand up, down, in and out of gear. I'm not really liking the fact that I can start it in gear though, so can any of you please help with a clever solution :idea:
I know that splicing in a wire to run between the side stand wire and the neutral switch, and adding a diode to allow the current to run only one way, works with the stock set up...see drawing1. But, can anyone tell me if the the same solution would work with the way my wiring is at the moment...diagram2?
Cheers folks :thumbs:
