Shorai Lithium Battery - Given Up The Ghost.
Well, popped into the garage this morning and the battery has failed. Nothing spoiling as the new one will be here in the new year. 🤷‍♂️
Well, another development on this. 😐
My replacement Shorai LiPo battery arrived from the USA between Christmas and New Year, but has been sitting on the kitchen worktop since then. Anyway, today I measured the voltage out of the box (13.2v) and put it in the bike. It failes on the CTek charger after about 4 mins........bugger. :mad:
So I now have the same problem with my original battery and a brand new one, so it can't be the battery (extremely unlikely anyway). I can't see the battery fly lead being the issue, but just in case I connect the charger to the battery with the crocodile clips and it fails again at the testing phase.
I take the original battery (now out of the bike, showing 12.8v after sitting in the bike for 3 weeks not on charge) and put it on the charger. It gets to stage 7 on the charger quite quickly, so is holding charge. I take the new battery out of the bike and place on charge, again it gets to stage 7 and is holding charge. I'm baffled as to why it won't charge on the bike and can't think of anything that is drawing current.
Now I put my original battery on the bike and connect a 'SkyRich' LiPo charger I got with the Pani R to the bike. It's a simple bit of kit with only 1 LED, but has a maintenance / optimiser function. Pop back into the garage a couple of hours later and it's now showing as fully charged.
The only conclusion I can come to is that the CTek charger is detecting some very small voltage drop on the analysis phase when connected to the bike that it's taking as the battery unable to hold voltage.
So it looks like my original battery is OK, but I now have a spare. 🤐
I take the original battery (now out of the bike, showing 12.8v after sitting in the bike for 3 weeks not on charge) and put it on the charger. It gets to stage 7 on the quite quickly, so is holding charge. I take the new battery out of the bike and place on charge, again it gets to stage 7 and is holding charge. I'm baffled as to why it won't charge on the bike and can't think of anything that is drawing current.
With that many lithium batteries you should hold a category 2 precursors licence for explosives. ...
Does your shorai battery have a bms system on it?
have you gone in with the bypass mode on the ctek charger?
Aircon, don’t talk shit, you love a bit of battery booty call phone chat!
The problem only occurs when on the bike. Charge off the bike and it's fine.
However the Shorai batteries do have BMS and Shorai manufacture a specific charger to use that port. I might buy one of these, now that I have 2 of these batteries.
Sometimes the bms will see a charger input as a spike and prevent the action, hence signalling the fault.
my ctek has a mode which allows you to bypass bms signals. Its the same fault that gets thrown up when there’s not enough juice in the battery.
we used to have batteries thst would register as failed when they were too low as the bms system used to shut the whole thing down in order to protect what little charge was in there. Used to be a right bastard trying to kick them up the arse again. Your charger may not have that bypass function, I don’t know.
The CTek has a reset function, which I have used when the battery was in the bike, I got the same result.
Like I say, no issues when the batteries are off the bike.
This is what I use to charge the Shorai
It has the connector to the BMS port on the Shorai and can do a balanced charge monitoring each cell. It will handle Li-Ion, LiPo and LiFe lithium batteries as well as Nicad, NiMH and lead acid batteries.
Cost about £25 a couple of years ago. They are commonly available on eBay for charging batteries for drones, model helicopters, etc.
Like I said above Derek, I might buy the dedicated charger, but it is strange thet the LiPo CTek charges the Shido LiPo battery in the Pani R with no issues and this issue only occurs with the Shorai in the 1098R. 🤔
I'll have to look at the fly lead on the Shorai charger when it comes as the battery box cover on the 1098R covers this port. At the worst, I'll have to make a small hole in it. (y)
Because I don't know shit 🙃 Is there anything you can attach to the bike to record the draw down over 24 hours? Is it possible an earth has become dislodged so is creating a minimal outage draw down somewhere?
and the last bit of my lack of knowledge 😵 I had a continual flattening of a number of batteries in the ex's car. We ended up tracing it to the stereo but just to confirm it we took the stereo fuse out and sure enough it was but we couldn't find out why. Sometimes the least obvious is the most obvious when you've tried everything else
That ends my completely useless offering to this post 🤪
  • HaHaHa
Reactions: JAT
Just an update on this as @West Cork Paul referenced this thread today when trying to create a definitive LiPo thread.
The CTeK charger kept returning an error with either Shorai battery when fitted to the bike. So I bought the specific Shorai charger for the battery. It's been fine while plugged in and has a 'STORE' mode which keeps the battery at around 70% charge when storing to prolong the life of the battery, a quick switch to 'CHARGE' mode takes it to 100% quickly when you want to use the bike, but it starts no issues at 70% anyway.
I think the issue may have been the draw of the immobiliser on an older bike and the sensitivity of the CTeK charger to detecting it.
Pros -
  • I now have the specific charger for the bike which plugs into a specific port on the battery and monitors it
  • The battery is maintained at 70% while on charge
  • I have 2 batteries 🤷‍♂️
  • The bike starts every time
  • Zero issues with battery temp. That and the reg/rec staycool during use.
Cons -
  • I've bought 2 batteries 🤷‍♂️
  • I had to modify the battery strap to allow the specific fly lead to plug into the battery when on the bike.
  • I have a spare CTeK charger, but no doubt will own another bike with a LiPo battery in the future
  • The Shorai charger doesn't fit on my optimate stand(s) in the garage, it has to plug in close to the battery.
