monster_998
As Bob has already mentioned, Trish's Diavel is unwell.
It's backfiring badly but seems happier above 4000rpm on an open throttle. Bob noted that the rear exhaust is taking longer to heat up, suggesting that issue lies with the rear cylinder. We replaced the spark plugs, swapped around the coil packs, and changed the ECU for the standard one but the problem persisted.
Trish spent this morning searching forums and the like for similar symptoms. She found something on the Diavel forum that suggested the air pressure sensor could be playing up, so long story short, disconnected the sensor for the vertical cylinder (the hortizontal sensor will now handle the settings for both cylinders) and, bingo, bike is running OK. Reconnecting the sensor causes the backfiring to return.
I'm confident that this is the root cause but would welcome a second opinion.
Additionally, would it be OK to run the bike on a single sensor until a replacement is fitted?
