Removing swing pin
pate
Hi again folks no one said it was gonna be easy!!
I am trying to remove the engine/swing arm from the frame on my 748, I plan to get the frame powdercoated.
Problem, can't get the swing arm pin out, Could I be missing something.
I removed the threaded bolt from the RHS placed an allen key in the LHS, I can get the pin to turn, but not come out.
I tried soaking in WD 40 for a while, putting the bolt most of the way back in and giving it a few hits with a hammer and brass punch, sounds solid and ain't moving.
My thoughts are that it has seized in the engine casting, as the swing arm has bearings in it, does this sound right?
Any ideas how I can get the thing out, or have I missed something, I am even toyin with the idea of a wee bit of heat on the underside of gearbox casing where the pivot bolt goes through, but maybe cause problems.
Thanks for any help folks, the old gal will rise again!!
Allan
Hi Allan,
It's almost certainly siezed in the swing arm bushes that sit between the swingarm and frame, see items 33 & 34 in the pictire below:
Unfortunately this is not uncommon and can be VERY hard to shift, I've even had to resort to cutting the pin with a hacksaw blade between bush and engine case to release a captive pin before!
I've had a drift made that screws into the thread of the pin which you can put some serious force through without damaging pin or frame but it's been lent out to a buddy down South and he's currently away (he's in Iraq with the Air Force) so unfortunately I can't lend it to you for a few weeks.
Whatever you do, don't hammer the pin-end directly without a correct drift, otherwise you'll 'flare' the end and it will never push through the bushes - if this happens then your trusty hacksaw blade is the only option!
I'm just up the road in Selkirk so can come and take a look if you want?
Cheers for now and good luck!
Chris
Do you have a sketch of the drift ? Im a wee bit further up the road on the 697 but could probably machine a drift up for you if I have the correct die to thread the pin if yer in a hurry.
Hi Sam,
I had it made years ago but I can get the necessary dimensions from a spare pin I have in the garage, it'll be Saturday before I get a chance to get the details to you though as I work in Denmark through the week.
All it is, is a plain hardened steel pin with a turned down threaded section that screws into the existing pin. The plain shank is 0.5mm undersize from the ducati pin so you can 'push' (read: batter!) it all the way through the frame/bush/casing.
Cheers for now bud.................. Chris
