rear sprocket nut torque
thomp1983
evening does anyone know the torque value for the 5 nuts that hold the rear sprocket on for a 1998 916 biposto?
thanks
chris
i saw that in my haynes but i thought that was for the 5 cush drive rubber nuts or is it for the sprocket nuts also?
Aren't the 5 cush drive nuts and the 5 sprocket nuts the same thing?
They are an allen key socket on the other end.
The coupling assembly (or sprocket carrier) is held on by the large sprocket coupling nut. (156Nm)
Just saw pics of your bike on your thread, you do have sprocket nuts! I don't?
It may be because i have a renthal sprocket carrier that it's not in the manual, i hadn't thought of that till you just mentioned it. Guess I'll just measure the studs and use a generic torque for there size
In the absence of finding any other info ive torqued them upto 35nm and will keep an eye on them when i clean the chain
